January 2018
28293031
4wd conversion
Page 1 of 4 1, 2, 3, 4  Next
View previous topic View next topic Go down
4wd conversion
Post by Guest on 9/29/2011, 9:52 pm
im about ready to do the conversion on Ursalla. Has anyone done this before? Also lookin for some parts if you know someone with a 231 t-case or a d30 let me know. How much modification would it take to swing a d44 from a TJ under my Cherokee ?
Re: 4wd conversion
Post by 89WhiteXJ on 9/29/2011, 9:54 pm
Prob not too much modding for the 44, but the axle itself for cost a lot.
The 4x4 conversion should be easy if you have all the parts. What year cherokee do you have?
Re: 4wd conversion
Post by Guest on 9/29/2011, 10:01 pm
It's a '98
Re: 4wd conversion
Post by 89WhiteXJ on 9/29/2011, 10:07 pm
So make sure you get a TC out of like a 95 or higher. I am not sure the year they changed it but the spline count is diff in the older ones. I just say 95 to be safe. It shouldn't be too bad to do.
Re: 4wd conversion
Post by Lock~N~Low on 9/29/2011, 10:12 pm
"Dirty" and I have done a 4wd conversion on a 98 XJ
View user profile http://www.youtube.com/user/LockNLow?feature=mhee
Re: 4wd conversion
Post by Guest on 9/29/2011, 10:13 pm
Thanks if you come across any leads on parts let me know.
Re: 4wd conversion
Post by 89WhiteXJ on 9/29/2011, 10:14 pm
See there you do. Some "pros" to help.
Re: 4wd conversion
Post by Guest on 9/29/2011, 10:15 pm
L-n-L would yall be willin to help out with another one
Re: 4wd conversion
Post by Lock~N~Low on 9/29/2011, 10:18 pm
oh yeah..... Twisted Evil
Re: 4wd conversion
Post by 89WhiteXJ on 9/29/2011, 10:20 pm
Chris do you know the year they changed the spine count for the TC?
Re: 4wd conversion
Post by Guest on 9/29/2011, 10:22 pm
Right on it's probably gonna be a while for me to find the parts, but the hunt is on!!!!
Re: 4wd conversion
Post by Lock~N~Low on 9/29/2011, 10:29 pm
i dont know.....Yet study
Re: 4wd conversion
Post by 89WhiteXJ on 9/29/2011, 10:33 pm
cbarton wrote:Right on it's probably gonna be a while for me to find the parts, but the hunt is on!!!!
Not if you have the money ready. We can find parts I'm sure.
Re: 4wd conversion
Post by MudRaider on 9/29/2011, 11:58 pm
Parts can always be found if the price is right. Looking forward to seeing some good epics from this conversion. Seen this on Pirate and how its great to start with a 2WD, metal thicker or something like that at the spring mounting points.
Re: 4wd conversion
Post by 4x4troy on 9/29/2011, 11:58 pm
96 was the change
and this is a very easy swap,dang near all bolt in be done in a weekend.
Re: 4wd conversion
Post by 89WhiteXJ on 9/30/2011, 12:07 am
I think you have to cut the floor for the trans shifter to come though, but hey by now Troy should be a pro at cutting. Very Happy
Re: 4wd conversion
Post by 4x4troy on 9/30/2011, 12:18 am
yes on some a hole needs to be cut. but i think the 98 has a access panel that just needs to be removed. but i don't mind helpping. get it to my house it it could be done in a weekend.
Re: 4wd conversion
Post by Guest on 9/30/2011, 8:02 am
Finding the right parts and ALL the parts is more of an issue than the money
Re: 4wd conversion
Post by Guest on 9/30/2011, 8:06 am
Jp mag has an article called two doubled the I need to read again. It was pretty detailed,so it would help on the step by step
Re: 4wd conversion
Post by 4x4troy on 9/30/2011, 11:58 am
you need a front axle,tc,shift lever and brackets,front and rear driveshaft,and make sure your gears match in f/r. and if you wanna do a lift this would be the time to put it in. oh and a tc/tranny crossmember.
Re: 4wd conversion
Post by Guest on 9/30/2011, 12:02 pm
Thanx, the lift is already in but I'm considering replacing the 6.5" coils and spacers with rustys 9"ers and a long arm upgrade
Re: 4wd conversion
Post by Guest on 9/30/2011, 12:05 pm
Gonna need a 4.88 r&p, a new diff, and should also do the slip yoke while I'm at it
Re: 4wd conversion
Post by MudRaider on 9/30/2011, 8:53 pm
So where you at with the parts list? I'm a firm believer in gathering all the parts and then doing it. My first big project was a V8 swap into an S-10. Five months gathering parts and reading up on it, then two weeks from popping the hood off til I let the ex take it around the block. All in a driveway. No help, with any of it, so you are one up having all this available help.
Re: 4wd conversion
Post by Guest on 9/30/2011, 10:13 pm
Somewhere between a 2wd and a 4wd. Finally decided to commite to part 2 of Ursalla
Re: 4wd conversion
Post by Nick@HappyTrails4x4 on 10/1/2011, 12:51 am
cbarton wrote:im about ready to do the conversion on Ursalla. Has anyone done this before? Also lookin for some parts if you know someone with a 231 t-case or a d30 let me know. How much modification would it take to swing a d44 from a TJ under my Cherokee ?
swap is pretty straightforward. virtually everything is bolt on.
you can normally pull a d30 and a np231 pretty cheap at a junkyard like Normandy.
dont forget all these parts also.
-front driveshaft
-4wd shifter assembly w/ linkage
-you need a 4wd transmision.
-rear driveshaft from a 4wd with the same transmission and rear axle you are running.
-and with any junkyard axles or tcase's, i would plan to give it a good check up and rebuild if needed
or if you can find a cheap 4x4 XJ on craigslist with a blown motor or accident damage, you can just buy that for a couple hundred and have all the parts you need.
and as for the d44, im assuming you're talking about the front D44 out of the rubicon, correct? that should bolt right in. But if you happen to find a Front d44, i would definitely be interested in it... Very Happy
Re: 4wd conversion
View previous topic View next topic Back to top
