zuki dieselin after shutoff
Post by Guest on 10/11/2011, 6:01 pm
one of my apprentices has told me his little samuri is dieseling after he shuts it off. i'm really not sure which direction to send him. couldnt be too many things it could be, just not sure what without lookin at it.
Re: zuki dieselin after shutoff
Post by MudRaider on 10/11/2011, 10:18 pm
Check for vacuum leaks, and a loose distributor (if it has one) that could be advanced too far
Post by DIRTY on 10/12/2011, 12:14 am
Question
Post by Guest on 10/12/2011, 8:32 am
Thanx that's a good start
Post by Lock~N~Low on 10/12/2011, 9:19 am
i dont know much about deisel engines. they all Suck, Squeeze, Bang, and Blow.
Post by Guest on 10/12/2011, 9:21 am
Nah chris it's a 1.3l samuri and it's stays running real rough for a second after shutoff
Post by Lock~N~Low on 10/12/2011, 9:30 am
oh....thats a common problem for deisels. i forget what the exact issue is. i have heard people dealling with stuff like that on their trucks.
Post by Guest on 10/12/2011, 11:24 am
you sait it was "dieseling" like engine still turning over after the key is turned off? If that's the case then i think whats happening is the cylinders are hot enough to burn any fuel vapor without needing a spark from the plug. Maybe the plugs are either bad, incorrect or they are putting out a weak spark. If it is carburated then it might be somehow leaking fuel into the intake after its shut off. Mudraider is right on about the timing.
Post by DIRTY on 10/13/2011, 10:40 pm
YEP ,WHAT HE SAID
