What is axle wrap?
What is axle wrap?
Post by MudRaider on 11/9/2011, 10:36 pm
How do you stop this, hear it a lot in coil vs leaf discussions, but no one ever says what it is.
Re: What is axle wrap?
Post by Nick@HappyTrails4x4 on 11/9/2011, 10:41 pm
axle wrap is what it sounds like.
under hard traction/torque, the leaf springs will curve into a sort of "S" shape and then rebound back causing a sort of "bounce" this can be VERY violent and is normally responsible for broken axles, ujoints, driveshafts, ect.
a traction bar can prevent this because i stops the springs from twisting like that.
Post by MudRaider on 11/10/2011, 7:27 am
Nick@HappyTrails4x4 wrote:axle wrap is what it sounds like.
Are you talking traction bar like on a street Car? Bolts under the leaf spring on one end and has a snubber on the other? That seems crazy, something hanging under right there. Got any pics? Dirty said something about putting some on one of his, Maybe he can post a pic.
Last edited by MudRaider on 11/10/2011, 7:29 am; edited 1 time in total (Reason for editing : added ?)
Post by 89WhiteXJ on 11/10/2011, 8:11 am
There are diff ways to do the traction bars to stop it. Below is bad for rocks on top can be done too but has to be in the right place. 4 link is best so no leafs. You dont get it with coil springs b/c your upper and lower arms are holding the axle in place.
Post by MudRaider on 11/10/2011, 8:10 pm
What about the front if it is leaf spring. Will it do it to them also?
Post by Nick@HappyTrails4x4 on 11/10/2011, 8:20 pm
MudRaider wrote:What about the front if it is leaf spring. Will it do it to them also?
the front is not really prone to have that problem
check this thread out if you have time. it is the best example of a bunch of functional traction bar setups
http://pirate4x4.com/forum/showthread.php?t=775194
Post by MudRaider on 11/10/2011, 8:31 pm
Thanks, checking it out now!
Post by MudRaider on 11/10/2011, 9:28 pm
My head hurts after reading all that. that is a lot of info!
