OFF~CAMBER 4X4
Would you like to react to this message? Create an account in a few clicks or log in to continue.
April 2024
282930
jeep stuck in 4wd I_icon_minitime6/23/2015, 10:58 pm by OffRoadney
jeep stuck in 4wd I_icon_minitime6/23/2015, 10:47 pm by OffRoadney
jeep stuck in 4wd I_icon_minitime6/23/2015, 10:46 pm by OffRoadney
jeep stuck in 4wd I_icon_minitime6/23/2015, 10:40 pm by OffRoadney
jeep stuck in 4wd I_icon_minitime6/23/2015, 10:37 pm by OffRoadney
jeep stuck in 4wd I_icon_minitime6/23/2015, 10:31 pm by OffRoadney
jeep stuck in 4wd I_icon_minitime6/13/2014, 2:34 am by 4x4troy
jeep stuck in 4wd I_icon_minitime4/27/2014, 3:06 pm by 4x4troy
jeep stuck in 4wd I_icon_minitime4/27/2014, 1:17 pm by 4x4troy
jeep stuck in 4wd
+3
7 posters
jeep stuck in 4wd Empty jeep stuck in 4wd
Post by chope045 12/7/2011, 6:32 pm
my jeep is stuck in 4wd and i have no clue how to get it out ive tryed moving it into 2wd bu hand but its like its inbetween 2wd and 4wd i have no clue what to do now and i need my jeep so i can get to work
jeep stuck in 4wd Empty Re: jeep stuck in 4wd
Post by Pitbullguiller 12/7/2011, 6:47 pm
1st thing to check is to make sure that T-case has fluid... No leaks or holes.
What year make model do you have?
Also Automatic or Manual and engine & t-case details?
Post by Lil Pepè 12/7/2011, 7:16 pm
Might have to check under jeep where your lionkage hooks up to tranfer case I have lost some pins and had same issue,
Post by chope045 12/7/2011, 7:29 pm
its a 91 cherokee 4.0 auto all stock thats all i know i cant see the linkage its dark but ill look tomorrow and how do i check the fluid level
Post by Lock~N~Low 12/7/2011, 7:36 pm
What side of town do you live? If your close by I might be able to help..... I'm pretty familiar with xjs.
https://www.youtube.com/user/LockNLow?feature=mhee
Post by chope045 12/7/2011, 7:55 pm
im in orange park but my jeep is off of argyle at home depot
Post by Guest 12/7/2011, 8:15 pm
Could you pull the front driveshaft to get it home
Post by chope045 12/7/2011, 8:28 pm
im sure but i have no clue how to do that this is my first 4wd making me extremely new to everything underneath
Post by Lock~N~Low 12/7/2011, 9:05 pm
I can help you out... when is a good time to meet up. I can meet you out there or I can pick you up. Just let me know what you want to do.
Post by chope045 12/8/2011, 7:56 pm
so my buddy pick upped my jeep today and it was in 2wd i gess letting it sit it made its way back in to 2wd
Post by MudRaider 12/8/2011, 8:24 pm
^^^^^^^^^^^ Question Question Question Question Question Question Question
How is that possible? I thought the Cherokee's were all electric?
http://photobucket.com/fastfoodvwRaidersnorkel
Post by chope045 12/8/2011, 8:28 pm
i have no clue last night i tryed everything to get it out of 4wd but today my friend gets in it and its in 2wd
Post by Lock~N~Low 12/8/2011, 8:31 pm
They are not electric..... they have linkage to the transfer case.... some axles have a center link in the axle tubing that is controlled by a vacuum line.
Post by MudRaider 12/8/2011, 8:35 pm
I have a "buddy' that has a dodge p/u that his doesn't engage in the front and said it was something electrical causing it to not engage. Does he not know what he has?
Post by chope045 12/8/2011, 8:49 pm
this is my first jeep so im still learning about it
Post by Pitbullguiller 12/8/2011, 9:42 pm
Lock~N~Low wrote:They are not electric..... they have linkage to the transfer case.... some axles have a center link in the axle tubing that is controlled by a vacuum line.
You are correct!
Post by MudRaider 12/8/2011, 10:28 pm
You are correct!
So I guess I can probably find a loose cable somewhere and the doofus will have 4WD Question ROTFLMBFAO
Post by DIRTY 12/8/2011, 11:05 pm
You are correct!
no it could be electric like chevy dodge also went electric in some years
Post by MudRaider 12/9/2011, 6:11 am
Mad crap Mad
Post by 89WhiteXJ 12/9/2011, 11:14 pm
This is correct. they had the vac disco for a while. Im not sure the exact year they stopped. Odds are with the XJ that when u put it in 2wd the transcase went to 2wd. They way they are made inside it pretty much moves a sleeve down the main shaft. In my XJ with disco front axle it will say its in 4wd b/c the axle is still vac connected. The transfer case is really in 2wd though. Once u turn it off and let the vacuum pressure off it would not say 4wd anymore. ( I know the inside b/c I just pulled a few apart recently and learned how it all works.)
Post by MudRaider 12/10/2011, 9:54 am
That is some good insight into how it works. I can visualize that.
Post by chope045 12/10/2011, 7:32 pm
that helps me understand a lil more
- Similar topics
