jeep stuck in 4wd
+3
7 posters
jeep stuck in 4wd
my jeep is stuck in 4wd and i have no clue how to get it out ive tryed moving it into 2wd bu hand but its like its inbetween 2wd and 4wd i have no clue what to do now and i need my jeep so i can get to work
chope045- senior member
Re: jeep stuck in 4wd
1st thing to check is to make sure that T-case has fluid... No leaks or holes.
What year make model do you have?
Also Automatic or Manual and engine & t-case details?
Pitbullguiller- Hardcore member
Might have to check under jeep where your lionkage hooks up to tranfer case I have lost some pins and had same issue,
Lil Pepè- Moderator
its a 91 cherokee 4.0 auto all stock thats all i know i cant see the linkage its dark but ill look tomorrow and how do i check the fluid level
What side of town do you live? If your close by I might be able to help..... I'm pretty familiar with xjs.
im in orange park but my jeep is off of argyle at home depot
im sure but i have no clue how to do that this is my first 4wd making me extremely new to everything underneath
I can help you out... when is a good time to meet up. I can meet you out there or I can pick you up. Just let me know what you want to do.
so my buddy pick upped my jeep today and it was in 2wd i gess letting it sit it made its way back in to 2wd
i have no clue last night i tryed everything to get it out of 4wd but today my friend gets in it and its in 2wd
They are not electric..... they have linkage to the transfer case.... some axles have a center link in the axle tubing that is controlled by a vacuum line.
I have a "buddy' that has a dodge p/u that his doesn't engage in the front and said it was something electrical causing it to not engage. Does he not know what he has?
this is my first jeep so im still learning about it
Lock~N~Low wrote:They are not electric..... they have linkage to the transfer case.... some axles have a center link in the axle tubing that is controlled by a vacuum line.
You are correct!
Pitbullguiller wrote:Lock~N~Low wrote:They are not electric..... they have linkage to the transfer case.... some axles have a center link in the axle tubing that is controlled by a vacuum line.
You are correct!
So I guess I can probably find a loose cable somewhere and the doofus will have 4WD ROTFLMBFAO
no it could be electric like chevy dodge also went electric in some yearsMudRaider wrote:Pitbullguiller wrote:Lock~N~Low wrote:They are not electric..... they have linkage to the transfer case.... some axles have a center link in the axle tubing that is controlled by a vacuum line.
You are correct!
This is correct. they had the vac disco for a while. Im not sure the exact year they stopped. Odds are with the XJ that when u put it in 2wd the transcase went to 2wd. They way they are made inside it pretty much moves a sleeve down the main shaft. In my XJ with disco front axle it will say its in 4wd b/c the axle is still vac connected. The transfer case is really in 2wd though. Once u turn it off and let the vacuum pressure off it would not say 4wd anymore. ( I know the inside b/c I just pulled a few apart recently and learned how it all works.)
89WhiteXJ wrote:Lock~N~Low wrote:They are not electric..... they have linkage to the transfer case.... some axles have a center link in the axle tubing that is controlled by a vacuum line.
that helps me understand a lil more
