Ignition electrical problems
+3
mmcgorty
7 posters
Page 1 of 2
Page 1 of 2 • 1, 2
My starter solenoid went bad so I changed it.... but When I went to crank it I noticed that it only cranked for 1/2 second and now nothing (no start). Then I noticed that 1 of the 5 wires connected to the solenoid side where the main battery wire goes was not connected (My fault and I believe touching the grounded tub). Now no start nothing.. I am willing to pay to figure this out but I am on a budget.
After this I changed the Ignition switch as I thought that it might have been shorted but nothing. And there are no fuses just old school link fused wires.
It’s a 1987 YJ 4.2 (no computer) / Weber 32/36 / automatic trans.
Anyone good w/ this ignition electrical stuff? Could I have shorted the new Starter Solenoid ?
Pitbullguiller- Hardcore member
Re: Ignition electrical problems
There is a good possibility you did short it out. I would just take the new one back where I got it n say it doesn't work. Hopefully they'll give u a new one no ?'s ask. Goodluck.
JaxWranglerUnlimtd- Hardcore member
JaxWranglerUnlimtd wrote:There is a good possibility you did short it out. I would just take the new one back where I got it n say it doesn't work. Hopefully they'll give u a new one no ?'s ask. Goodluck.
I have lifetime warranty on it from Orilleys Auto Parts and I am picking up the new one tonight and will post my results.
Thanks!
I just had the same issue with mine and it turned out to be the ICM. Since i put that on i havent had any issues.
mmcgorty- member
mmcgorty wrote:I just had the same issue with mine and it turned out to be the ICM. Since i put that on i havent had any issues.
Thanks man!
Question: Was your engine turning over with the key on the start position? Mine is not even turning over and All fuses are good.
Melvin at Happy Trails re-wired mine by-passing the computer. Thats means I no longer have the computer in my YJ... but I do believe that the ICM (Ignition Module) is still connected. But its about 100 bucks. Where did you get yours from and how much?... if you dont mind me asking.
Yeah mine wouldnt do anything. I think i picked it up at autozone for 45.00 but i would shop around.
mmcgorty- member
mmcgorty wrote:Yeah mine wouldnt do anything. I think i picked it up at autozone for 45.00 but i would shop around.
Thanks again, Matt!
I just found it with lifetime warranty at autozone for $34.99. I miss driving my jeep and cant wait to get her running again!
Trust me i know the feeling, im waiting on some bolts so i can get mine back on the road.
mmcgorty- member
1987 JEEP WRANGLER 4.2L 258cid L6 : Ignition : Ignition Control Module (ICM) Wiki Price
STANDARD MOTOR PRODUCTS Part # LX203T T-Series
w/ OEM # w/ OE No. 8933004065;
$15.29
Add Part
UNITED IGNITION WIRE Part # M184
$18.58
Add Part
KEMPARTS Part # E302
Ignition Control Module/Unit [Wholesaler Closeout -- 30 Day Warranty]
$20.79
Add Part
KEMPARTS Part # E302X
$20.79
Add Part
AUTO-TUNE Part # E313D
Ignition Control Module/Unit [Wholesaler Closeout -- 30 Day Warranty] (Only 10 Remaining)
$21.79
Add Part
OMIX-ADA Part # 1725202
$27.79
Add Part
STANDARD MOTOR PRODUCTS Part # LX203 {Click Info Link for Alternate/OEM Part Numbers12334611, 19110488, 3230451, 33004065, 8933004065, D6AB12A199A1B, D6AB12A199A2B, D6AE12A199A1A, D6AE12A199A1B, D6AE12A199A1C, D6AE12A199A2A, D6AE12A199A2B, D6AE12A199A2C, D6AE12A199AA, D6AZ12A199A, D6AZ12A199B, D6TE12A199A1A, D6TZ12A199A, D7AZ12A199B, D8AE12A199A1E, D8VE12A199A1A, D8VE12A199A1B, D8VE12A199A1C, D8VE12A199A2A, D8VE12A199A2B, D8VE12A199A2C, D9VZ12A199A, DY184, DY184A, DY184B, DY184C, DY184CDP, DY198, DY337, DY611, DY683, E1FZ12A199A, E8PF12A199AA, E8PF12A199AB, E9VZ12A199A, E9YZ12A199A, F1910, F2PF12A199AA, F2PZ12A199A, F2PZ12A199AA, J3230451}
$27.79
Add Part
AIRTEX / WELLS Part # 6H1012 {Click Info Link for Alternate/OEM Part Numbers12334611, 3230451, 33004065, 827498C1, 8933004065, D6AE12A199A1, D6AE12A199A1A, D6AE12A199A1B, D6AE12A199A2, D6AE12A199A2A, D6AE12A199A2B, D6AZ12A199A, D6AZ12A199B, D6TZ12A199A, D7AZ12A199B, D8VE12A199A1, D8VE12A199A1B, D8VE12A199A1C, D8VE12A199A1L, D8VE12A199A2, D8VE12A199A2B, D8VE12A199A2C, D9VZ12A199A, E1FZ12A199A, E9VZ12A199A, F102, F2PF12A199AA, F2PZ12A199A, F2PZ12A199AA, J3230451}
$15.29
Add Part
$18.58
Add Part
$20.79
Add Part
$20.79
Add Part
$21.79
Add Part
$27.79
Add Part
$27.79
Add Part
Ignition : Ignition Control Module (ICM)Related Parts
$15.29 $15.29
Subtotal $15.29
Shipping: Ground (1 to 5 business days) ($8.52)
Total $23.81
$15.29 $15.29
Subtotal $15.29
Total $23.81
4x4troy wrote:1987 JEEP WRANGLER 4.2L 258cid L6
$15.29 $15.29
Subtotal $15.29
Total $23.81
Troy, that is the best price so far! Thanks man!
I called Oreillys Auto back and they had quoted me the PCM and not the ICM that’s why the originally said 112.00 but theirs is actually 27.99 w/ lifetime warranty and I am picking it up tonight cause I can’t wait any longer.
I like Rock Auto and all, but for $4 to get it right away is definitely worth it. i mostly have used them for wheel bearings, all the engine stuff for the Shogun. Also all the brake parts. Basically planned maintenance stuff.
Yep, never been disappointed by any of the parts I have gotten from them.
It was not the ICM.
So far Ive replaced ICM Ignition Module, Ignition Switch, Starter Solenoid, replaced Starter to battery 4 guage cable, and tested starter at the auto parts and still cant figure it out. Does not even try to crank, like dead! Battery is a brand new 34 Optima blue top. I am thinking there is a short somewhere in the ignition wires.
R u getting spark? Are u getting fuel? These are the first things u should've checked if u didn't already. Sounds like lack of spark but always need to be sure. Did u do a continuity test on the ignition system to make sure power is coming in n going out? Do your headlights or radio work? I know u said battery is new but did u check the voltage coming out? Maybe it needs a jump cause not enough juice. Maybe u burned a cell in battery.
Can you just the starter sol. with like a screw dirver and get it to turn over? That will cut out most the wiring and be straight batt to starter. If it turns you know those items are good. If not you know your problem is somewhere in there. What part of town do you live in?
89WhiteXJ wrote:Can you just the starter sol. with like a screw dirver and get it to turn over? That will cut out most the wiring and be straight batt to starter. If it turns you know those items are good. If not you know your problem is somewhere in there. What part of town do you live in?
It will crank right up if I jump the starter. But its not the Solenoid cause I have changed 2 times in the last week. I am in Mandarin by the way.
Im sure. Did u check to see if when u turn the key over u are getting power to the solenoid.
89WhiteXJ wrote:Im sure. Did u check to see if when u turn the key over u are getting power to the solenoid.
Checking that tonight or tomorrow.
Cool. It can not be that hard to track down.
Page 1 of 2 • 1, 2
Similar topics
» electrical problems
» Computer problems
» brakes sticking and over heating problems
» Resolving problems in Recreational Clubs
» Computer problems
Page 1 of 2
