May 2018
6789101112
13141516171819
20212223242526
2728293031
tow rig
Page 2 of 4 Previous  1, 2, 3, 4  Next
Re: tow rig
Post by 4x4troy on 2/3/2012, 6:14 pm
prior to 00' tj's had a 3spd auto. mine is factory 3:73's. yes it does seem strage that the cherokee has a 4spd auto but the tj did not. but it is a fact that tj's came with the 32re(rh) tranny. i am guessing at the 4:10's because when i had the stock 30's on here speedo was slow now with 31's its right on same mph as gps now
Re: tow rig
Post by Guest on 2/3/2012, 7:56 pm
Odd
Re: tow rig
Post by JaxWranglerUnlimtd on 2/3/2012, 8:01 pm
Do u know how to tell what gear ratio is? Lift the rear of jeep n rotate tire, mark tire then count # of revolutions at drive shaft when u spin tire once. That will tell u how much. If 3 3/4 at driveshaft for 1 tire spin then 3.73. If 4 then 4.10 n so on. The TJ is a 3spd with od.
Re: tow rig
Post by Guest on 2/3/2012, 9:14 pm
Yes ring divided by pinion
Re: tow rig
Post by Guest on 2/3/2012, 9:24 pm
No overdrive, 32rh has a 1.00 3rd gear. Question
Re: tow rig
Post by Nick@HappyTrails4x4 on 2/4/2012, 1:52 pm
89WhiteXJ wrote:Well that's kinda true. A lot of guys drive there stuff places. I drive with 35s and play. Nick drives with a welded rear. Jeff drives and u have seen his yj. Mike drives his wrangler. But if I had a tow truck/van I might use one too.
this is true, while i can and have driven my jeep a good distance to go wheeling... it is nice to be able to just toss it on a trailer and not worry about tire wear, or possibly breaking something a few hundred miles from home
Re: tow rig
Post by Nick@HappyTrails4x4 on 2/4/2012, 1:57 pm
4x4troy wrote:prior to 00' tj's had a 3spd auto. mine is factory 3:73's. yes it does seem strage that the cherokee has a 4spd auto but the tj did not. but it is a fact that tj's came with the 32re(rh) tranny. i am guessing at the 4:10's because when i had the stock 30's on here speedo was slow now with 31's its right on same mph as gps now
AW4 swap!!
Re: tow rig
Post by 4x4troy on 2/4/2012, 3:28 pm
i like the 3 spd. all other jeeps sites say its alot stronger then other jeep autos. and it has no od....3 gears only.....at 60 mph i am turning 3300 rpm.
Re: tow rig
Post by DIRTY on 2/5/2012, 1:45 am
need bigger tires to make it equal out
Re: tow rig
Post by 4x4troy on 2/28/2012, 11:54 pm
got me a tow rig. a 2001 ford f150 4x4 supercab. i will post some pics tomorrow. not really pretty but runs great and its the 4x4 offroad version with the tow package and 5.4 v8
Re: tow rig
Post by 4x4troy on 2/29/2012, 1:03 pm
here is my "new" ford....
Re: tow rig
Post by MudRaider on 2/29/2012, 2:41 pm
Keep an eye on the spark plugs. My work truck popped them out a couple times. total PITA to fix. The spark plug holes are straight down, kind of under the manifold. Not one of Ford's better ideas.
Re: tow rig
Post by chope045 on 2/29/2012, 3:27 pm
my buddy just got rid of one of thos had over 200000 miles and still ran great
Re: tow rig
Post by 4x4troy on 2/29/2012, 6:06 pm
this runs great and has 335000...pulled behind a motorhome for years and dang good maintence done on it. yeah mudraider i have had a few of these 5.4's.....is a PITA to change #4 the rest are ok....but this one just had it all done.
Re: tow rig
Post by lordbiotree on 2/29/2012, 7:28 pm
Should have like a 7K tow rating. It'll pull your jeep fine. As long as you don't get tall or to crazy with the jeep.
All I know about the ford modular motors is get the aftermarket solid piece design spark plugs. If the plugs have been done before usually there's no issue.
lordbiotree
newbie
newbie
Re: tow rig
Post by DIRTY on 2/29/2012, 8:04 pm
exhaust manifold bolts break easy
Re: tow rig
Post by JaxWranglerUnlimtd on 2/29/2012, 9:41 pm
Here's something to tow behind it. Plus u could double it as a camper.
http://tampa.craigslist.org/hil/rvs/2873164698.html
Re: tow rig
Post by Lock~N~Low on 2/29/2012, 10:05 pm
What size lift are you gonna put on that?
Re: tow rig
Post by 4x4troy on 2/29/2012, 10:54 pm
dont know if a f150 would hadle that...lol. this one is staying stock. its a dd
Re: tow rig
Post by 89WhiteXJ on 3/1/2012, 9:59 am
Watch the wheels they seem to want to turn while you are driving it. Its a common issue on those.
Re: tow rig
Post by 4x4troy on 3/1/2012, 10:31 am
lol yeah...the back one on this one like to smoke for some reason....i have already bough new tires for it...lol...now i just need some 16" wheels i dont like the 17's on it.
Re: tow rig
Post by 4x4troy on 3/6/2012, 12:38 am
well here is how it looks now.....i put steel wheels on and painted them white,had a new windshield installed, put in a new headlight switch...still need to install the swaybar links
Re: tow rig
Post by Lil Pepè on 3/6/2012, 7:54 am
Looking good, do you plan on keeping it?
Re: tow rig
Post by 4x4troy on 3/6/2012, 12:37 pm
yes this is my dd now and tow vehicle for my jeep and the cars i buy to sell. i also have a 18' dual axle car trailer now with a winch.
Re: tow rig
Post by Lock~N~Low on 3/6/2012, 1:27 pm
Sweet ride. Looks good
Re: tow rig
