May 2018
6789101112
13141516171819
20212223242526
2728293031
motor swap almost done
Post by chope045 on 2/29/2012, 3:41 pm
i have the motor sitting in the engine bay all i have left is bolt up the tranny if anyone wants to lend a hand i would appreciate it
Re: motor swap almost done
Post by Guest on 3/1/2012, 9:34 am
Good luck! Sorry that everyone has been pretty busy lately, but hope you get it finished before the poker run.
Post by Lock~N~Low on 3/1/2012, 9:49 am
Yeah. I would like to help, but I've been super busy.
Post by MudRaider on 3/12/2012, 11:19 pm
This thing running yet???
Post by chope045 on 3/13/2012, 7:34 pm
not yet works picking up so now i only have weekends to work on it gona try and get a new ecu and see if that helps
Post by MudRaider on 3/13/2012, 10:26 pm
chope045 wrote:not yet works picking up so now i only have weekends to work on it gona try and get a new ecu and see if that helps
Doesn't make sense to me. Is it trying to fire? Did you put all your old parts on this engine or is it got another vehicles electronics on it. Yours was running, electronically it should fire if you're using you're old parts.
Post by Lock~N~Low on 3/14/2012, 4:22 pm
It makes sense... he has a '91 harness and a '99 motor. Totally different sensors. He will have to splice a couple of wires.
Post by chope045 on 3/14/2012, 4:44 pm
i switch all my sensors on to the new motor so i dont need to splice anything
it turns over but isnt getting spark or pulse to the injectors
Post by DIRTY on 3/14/2012, 10:57 pm
almost there
Post by Guest on 3/15/2012, 9:13 am
Possible crankshaft position sensor?
Post by Lock~N~Low on 3/15/2012, 9:43 am
Yeah..... is it throwing a check engine light code?
Post by chope045 on 3/15/2012, 10:24 am
we thought that to but after checking it there is no damage
Post by Guest on 3/15/2012, 11:19 am
Mine never threw any codes when it went. No physical damage but same symptoms
Post by chope045 on 3/15/2012, 9:55 pm
well thats cheaper that a ecu ill try that this weekend
